Help Help
googler1
Okay, so I have an HTC HD2, yes I am aware that it is NOT indeed a DESIRE. I just want to know how can I put ANDROID on the HD2. I have tried MANY times and I fail at it. I always get stuck at the green HTC logo. If anyone knwos how to. THANKS!
Hello googler1,
I Have found this topic which I think should help you! Good luck getting Android on your phone, its the best OS I have used to date.
Guide to getting Android on your HD2 - Start to Finish
Thank you, but i have laso done that. i am prbably doing something wrong. i have tried MULTIPLE roms sites and nothing..
Hi googler,
I have merged your two threads together into this thread in the HD2 section. I know your phone uses Desire HD ROMs, but I don't think you'll get much help on that topic from the DHD section.
Also, you can hit the
button on your post if you make a typo and want to go back and change it :)
To googler1, question, do you want to run android from the sd card or from nand? Either way, you should format your sd card and do a clean install of the rom you want to run.
