help
liljc
some one please help me.. i think my phone may be bricked
Okay... so I try and use my camera on my lg Etna, and it wont work, i try to access the internet and that wont work, i try to take my phone off of airplane mode and of coarse that wont work, my gallery wont open, i cant access the torch app, and i cant put music on my phone, and when i plug my phone into the computer i get "device is not fully installed" when i do have every thing on there but it still wont work.. what the f*** man?? can some one please help me??:mad::confused::confused::confused::confused::confused:
Hi there, welcome to the Android forums. Which phone do you have? The forums have specific forums for each phone, so if you'd like, you can find your phone in the list and go to that forum and hopefully get the help you need.
Android Phones - Android Forums
There's a lot of good people here, and hopefully you can find the help you need for your phone.
Ooops, I apologize, I misread the 1st post. I don't happen to see the LG Etna listed. I will look around and see if I can figure out the best direction to point you in.
