Root Help
droidfan1
I want to go from .595 to .596...
I have currently baseband .07 so I think I need to sbf to get to .12
I need .340 sbf, yes? Where do I get the files?
Can I do this? Update.zip sbf from TBH. Then from MDW, part 1 + 2 gb to get .12 baseband. Then deodex gingerbread, then apex?
If you have the .07 baseband then yes you have to sbf back to stock and flash tbh's 2 files. To get everything you need check out the newbies sticky at the top of the forum.
