go to setting -> wireless and network settings ->tethering and portable hotspot -> den check the usb tethering button.
if the above step wont work, make sure that u connect the data cable so that the phone cannot be used as an usb/memory card .if this is ok, den it has to tether automatically and u can use net directly.otherwise its problem with ur data cable
