Help....
Welcome to the forums.
Hi there, what tablet is it? If you enter the incorrect code multiple times, does it not prompt you for your google account info?
Failing that, you can try a factory reset via the boot menu. On a number of phones, the boot menu can be accessed by holding certain button combinations down on boot. If you let us know which tablet you have, we'll be able to provide more assistance.
Welcome to Android Forums!
The pattern unlock should give you an option to unlock with your google account after a fixed number of failed attempts.
