help.....
hai...! i am a new to this forum...
currently i am using nokia3110c(WTF)..:eek:..
was planning to buy a new entry level andro...
which of the following is good...
galaxy5...
galaxy3..
galaxy mini(pop in india)...
optimus me..
i think the mini fits better to my budget...what do you think...? please help me out...?
i know "optimus one" is better but costs little high..:(
should i buy a galaxy 3 and upgrade it to 2.2 or buy mini...?
and also suggest me if their are any good ones in this range...
galaxy5...
galaxy3..
optimus me..
Welcome to the forums!!
Unfortunately I can't help on the "best to buy" or which would suit your budget best (only own 1 device myself). I hope that someone else will be able to advise! :confused:
If you go to http://androidforums.com/and scroll down, each device has it's own sub-forum... you may get some responses as to the features of each phone, so you can compare them.
The best advice may be to actually go in to a shop and get a feel for each one, that way you will know which one you like best! :)
EDIT - most people would give you reasons why their device is best but, ultimately, the choice is yours!! :)
thanks for the reply...the think that is confusing me is this...
galaxy 3 has has a better screen and a cam with auto focus and a better batterry costs less..
the mini has a better ram and comes with stock froyo...but no autofocus and weak battery costs little more..
will the lack of autofocus and a smaller resolution limit me from using the device to full potential...?
or is a phone with larger ram is better..?
I wouldn't have thought that the resolution should be a problem... battery life is usually quite important though... I have a Desire HD and the battery life is, quite frankly, rubbish (unless you follow a few "rules"/tips to get as much out of it as possible)... I'd say - go for the best bang for your buck... weigh up the options and get the best all-rounder!! :)
Small_town_boy... I think a lot of users do not check in the introductions section of the website... you may get better answers by asking in the sub-forum for each device. The owners of each device could then let you know why they think their device is the best and then you would be able to make a decision based on their comments!
EDIT - it is worth noting that you said that Galaxy 3 comes with stock Froyo... Froyo has recently been replaced with Gingerbread
