Help Help
hey guys i must have change a setting some where on the phone but i cant get it to ring on messages or phone calls now all it does is beep ive check its nt in silent and tried to change the ringtone. can anybody help ?
did you check the volume settings in the sound menu? maybe you changed the values there :confused: and what do you mean with all it does is beep? :D sounds weird to me
when recieving message or call it just makes a low beep twice i've put all the volumes up to max but no luck if i try to change the message tone it beeps the same as when i recieve a message but no tone
its sorted now...... some guy told me its to do with when u plug the head phones in and take them out ..... just had to turn it off n bk on then change the tones again :S sounds simple but wrked :)
sounds kinda broken but i'm no expert and never had this problem. your phone isn't by any chance rooted? what about other sounds? playing media? i'd do a factory reset if i were you but maybe there's sb else who knows a better solution :p sorry
