Note there are two versions of the rOCK kernel. The one in the first post only works with CM7, the one in the second post is for any ROM. If you are not on CM7, reflash the kernel using the one in the second post (anyROM v0.3). Afterwards, wipe cache (and dalvik cache as well I believe) then reboot.
