Help
Hi friends.
I have samsung galaxy Y ie., S-5360.
Whenever any application is installed through android market,
it directly goes to phone memory and the message is displayed
"Low Internal Memory" Please tell me the way so that all the applications
are saved on memory card rather than phone memory.
Also tell me what is the default pasword of the phone.. if any ..
Thnx
ashish
Hello and welcome to Android Forums, ashishshukla19.
Your device is listed as having 180 MB, 290 MB RAM as memory and a 32Gb capacity SD card can be used. What size is the SD card you're using?
I'd just uninstall all 3rd party apps and widgets, reboot the device, then try installing them one at a time until the error message comes up again, then uninstall the last one.
Having said that, I'm wondering if you've go a corrupted SD card, which can happen even with a new one. You can test that the obvious way, by replacing it, or you can try reformatting the one that is in there, then reinstalling everything.
Good luck. Post back and tell us how things are going.
Here's a link to our Samsung Galaxy Y forum for you:
http://androidforums.com/samsung-galaxy-y/
Hi,
Welcome to the forum. Most applications are automatically stored to the phone memory and not to the SD card. However, you can manually move application(s) to the phone SD card. One way of doing this is to Tap menu -settings-applications-storage use-on SD card, then check the box of the application(s) you need to be stored d on the SD card.
Enjoy stay here.... See ya around. :)
