Help Help?
Well , as i was updated android, it froze up halfway through and now phone won't connect to data or service. Went to Telus- no help, called Loyalty- no help there either. Is there anything i can do to go back to original shineplus? thanks in advance guy and gals:mad::mad::mad::mad::mad:
Did you update using the official tools? If you did, you can reflash using these instructions. You may need to find a copy of the kdz elsewhere. Try this thread.
If you check your phone for the version info, what does it say? does it say v10c/v10d or v20a?
If it still says v10c or v10d, you can still roll back to the original rom. If it says v20a, you'll need to reflash the new version 2.3.3 using the links I posted above.
hope this helps
Thanks ,I have v20a . Can't seem to find a working KDZ file though, will try tonite, but in the meantime ,bitching at telus and lg :), Thanks again jiilik
