Root Help
Evil1
I have a rooted android and today I let the battery die and can't turn it back on. A few days ago my power button quite working and when I plug it in to charge it goes to the bootloader. What can I do?
Well, it looks like you might be in a tight. I always use at least two batteries, but that's another story;, plug your A855 into the stock OEM wall charger that came with the phone and leave it there until it is fully charged. You will not need to use your power button that has quite.
Once you let it fully charge via the stock wall charger, then we may be able to help you along your way.
good luck
