Help !
Press the power button, the home button, and volume down to boot into recovery mode. You might be able to do a factory reset.
From where did you install your cyanogenmod? If you installed from cyanogenmod mirror network for the device ace, you can't do anything. Our phone codename its cooper in cyanogenmod and ace is for htc ace!
Yes, an important difference! ;) The HTC Ace is the HTC Inspire (in the U.S.), not related to the Samsung Galaxy Ace (other than being Android OS).
if you are getting a blue screen and everything disappers then wait for 5 minutes, the first tiem it takes some time to load.
Worked for me!
