Root help
ok. so i had a rooted phone. no problems. then i upgraded sd card and the trouble happened. needless to say i ended up unrooting with gingerbreak(what i used to root). i verified this with root checker. all my root apps stayed on my phone tho along with superuser. i then tried to root again with gingerbreak and now it wont let me successfully root. any help is appreciated.
this is the message i got from root checker when i ran it on my phone after trying to root.
Root Access is not properly configured or was not granted.
Superuser Application Status:
Superuser application - version 3.0.7 - is installed!
System File Properties for Root Access:
Alternative Location
Check Command: ls -l /sbin/su:
Result: /sbin/su: Permission denied
Analysis: File system permissions restricted and denied access.
Standard Location
Check Command: ls -l /system/xbin/su:
Result: /system/xbin/su: No such file or directory
Analysis: File /system/xbin/su does not exist.
Standard Location
Check Command: ls -l /system/bin/su:
Result: /system/bin/su: No such file or directory
Analysis: File /system/bin/su does not exist.
Check Command: ls -l /system/xbin/sudo:
Result: /system/xbin/sudo: No such file or directory
Analysis: File /system/xbin/sudo does not exist.
Root User ID and Group ID Status:
SU binary not found or not operating properly
System Environment PATH: /sbin /system/sbin /system/bin /system/xbin
ADB Shell Default User:
ADB shell setting for standard access, stored in default.prop, is configured as: shell (non root) user - ro.secure=1
Results provided on your VM670 device by Root Checker Pro version 1.2.7 from joeykrim in the Android Market - http://goo.gl/NcnHn
Sent from my LG phone
