help
Goggle sign in error.passwords correct. Says something bout account activity or something
Welcome aboard. That simply means that the credentials you are using does not match the ones on record. Follow olbriar's suggestion and clear data from the application you are using. Or clear cookie, data, history, etc from your web browser.
To clear data from an application … Go into settings - applications - downloaded - find app and clear data.
To clear cookie, data, history, etcetera ... From any webpage tap on menu - more - settings - scroll down to the above mentioned and clear as follows.
