help
ive been playing around with my lg connect been trying to flash roms but failed so i finally gave up but now when i try to play games it crashes and goes back to my home screen ive tried everything such as factory reset flashing the stock rom, wiping chache, wiping dalvick chache nothing seems to work please help me
Welcome to Android Forums, look around and enjoy.
Be sure to check out the sections dedicated to your Android device( Android Phones - Android Forums ) and your Carrier ( Android Carriers - Android Forums ).
For Tablets check this section out, ( Android Tablets & MIDs - Android Forums )
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
Which model LG do you have so we can guide you in the proper direction to get the best possible response for your issue
The best place to find help with this problem will be inside its support forum. Hello and welcome aboard. Sorry to hear about the problems you are having - hopefully someone will chime in to assist you.
Best of luck. ツ
