Root help..
Skata3000
I just completed installing Monster 5.3 on my non overclocked admire.. i thought all was good until it just sits at the android screen.. but the weird thing is the ROM is still running in the back.. for example when i tilt the phone sideways i see half of the setup screen where you touch the android to begin... i know this might sound a bit confusing but im new to the android scene. and me being dumb.. i didnt back up my original GB
Woah, that's weird, I forgot where but there's a stock samsung admire cwm backup that you can put on your sd card (/clockwork/backups) and restore it back to Stock
i've tried your suggestions.. But to no avail. i'm planning on re-installing Win 7 verbouse and finding a different ROM. it isnt bricked i know for sure. i can get into Recovery no problem.
Stock ram? sorry im a bit new to android
*edit: i just realized you made a spelling mistake.. I know what you mean. i'm attempting to move a restore of the stock 2.3.4 with a file i just found will report back with details.
