M monstarh Lurker Oct 23, 2012 #1 what does it mean when your battery flashes when it's full & obviously the battery is in otherwise it wouldn't be on.
Digital Controller The Real Bass Creator Oct 23, 2012 #2 Welcome to the forums monstarh! Glad to have you here and hopefully i can try and assist you with the issue you are having First off could i get some more information, where is it flashing, and what device are you using? Secondly, do a battery reboot on the device by removing the battery and reinserting and restarting the device. Thanks in advance for more information!
Metroid Prime Oil Can!!! Oil Can!!! Oct 23, 2012 #3 Hello monstarh and welcome to Android Forums. What color it the LED light flashing? You could try what DC suggested to see if that resolves the problem.
Rush {<>}~{<>} Oct 23, 2012 #4 monstarh said: what does it mean when your battery flashes when it's full & obviously the battery is in otherwise it wouldn't be on. Click to expand... Hello and welcome aboard. This can happen while charging and using the device at the same time. This usually happens if the battery get to hot. As suggested above, taking the battery out and reinsert it should get things back to normal. Welcome to the community.
