Digital Controller The Real Bass Creator Dec 6, 2012 #2 Welcome to the forums! That is quite an issue you have there, so you will need to side load the play store. I think you can follow this set of instructions: https://developer.android.com/google/play-services/setup.html Hope this helps
Mikestony ~30% Carbon Black ± VIP Member Dec 6, 2012 #3 Welcome lilgenerals! Navigate to here with your device browser and download the .apk from there and install the apk. Download: Latest Google Play Store 3.9.16 - Remove Entries From All Apps, Keep Track Of Position In Lists, Expandable Notifications, And More Hope this helps and thanks for joining
Rush {<>}~{<>} Dec 6, 2012 #4 Welcome aboard. Follow the steps above this post. You can find some cool info and tips inside your device's area of support. Good luck.
