Help!
Ok, this is my first post so sorry if its in the wrong place or w/e
I got my acer iconia A110 for Xmas and since then its been dropped a few times and the case/cover/body, whatever its called has broken, Its only the grey backing peice that has broken and i was wondering if there is any way to buy a new part and where from?
I hope this makes sence lol
Hope someone can help
Welcome to the forums, LadThornton!
Can't seem to find any parts on eBay which is usually a go to. But, looks like a new one isn't terribly expensive and it may be better to replace it rather than fixing it. :(
Also, perhaps there's a case out there you can use to cover up the back? Are the internals still in one piece?
Hello LadThornton. Let me add my "welcome" to dreadnatty's. :)
Acer Iconia Tab A100 Series AC Adapter Plug EU - acerparts.ca is a site which lists quite a few Acer part categories on the left side of the page (the main page there being about the adaptor, which you don't need ;)). Have a look, perhaps the piece you need can be purchased after all.
If you bought the tablet with a Credit card, there is a good chance they may cover accidental cover, many of them do.
or
Contact Acer, I had a dodgy charger, they reponded quickly with a replacement.
