help?
you can either do that in uot kitchen or did what I did,
actually going into the framework
extracting the images and then recolor in gimp (note replacing layers)
then replace the images
its one of the first tabs in the kitchen. u can customize icons or add icon packs. it will give u the option to put in ur own color code for the icons. explore around where it deals with customizing icons... u will find it!
