PrinceCorwin
Android Expert
I tried the pwnage tool. I think the connection was loose because the command prompt got stuck on "waiting for reboot". My phone had finished rebooting but the debugging and internet connection icons were not in the notification bar. When I lifted the phone, they came back and the prompt said everything failed and then "rebooting one last time". That stayed that way for almost an hour with nothing happening. So I x'd out of the command prompt and started over. After I chose "n" for "am I rooted", nothing happened. Also, my phone now says "no service" and I can't uncheck debugging. It's greyed out.
What do I do now?
What do I do now?
Thread cleaned.
