Help
Hello and welcome aboard. :)
Thanks for stopping in to join our forum. Sometimes this kind of problem usually goes away, however...if the problem persists, then i would suggest uninstalling applications you recently installed.
You should stop inside your device's support forum where you can find some helpful info and tips on this device.
Good luck.
