Help
  • Start date Start date
A
Android Question
Guest
I have a motorola droid. Like an idiot, I dropped it this morning. It is totally my fault. The screen shattered. It is still on. I can tell when I get messages but it won't turn on and I can't read the messages. It also won't turn off.... but the screen is not black. It is like when I first turn it on but when I touch the dot in the middle of the screen to turn unlock it, it won't unlock. Is there any hope.
I can't get any calls either.
Connect the phone to a computer (with the USB cable). Save anything you can get. If you put your contacts i as account contacts (unbder your Google account), they're saved on the cloud.
That's about the best you can do as far as saving data, Then you'll have to get the screeb repplaced or get a new phone, your choice.
