help
  • Start date Start date
A
Android Question
Guest
on my alcatel one touch evolve my calls go directly to voicemail what can I do to fix this? and my car is bluetooth compatible how do I sync my phone to it
1) Call your carrier for help.
2) Read the car manual. Does it want to be discovered or does it discover? That tells you which one (the car or the phone) to put into "Visible" or "discoverable" mode and which one to search or scan with.
