Help help
theo2013
is there any way to factory reset a htc sensation my partner is now using it with his sim but when it came to texting me it only brings up my number not my name I tried deleting it and entering it but for some reason at the top off my contact list is my number n no name and I cant delete it
Hi theo2013. Welcome to Android Forums. I don't own a Sensation but I think the HTC's are the same. Go into your settings via the option in your app drawer. Click on Storage. There should be an option to Factory data reset the phone. Be certain you have backed up all precious items on the phone.. for they will be wiped clean.
If this is not the correct procedure for your phone, I'm sure a Sensation owner will chime in soon. Good luck and thanks for joining the community.
