I have been messing with my phone lately, installing ROMS to check them out and wiping & installing. All has been great up until now.
I wipe all data, cache, factory reset & dalvik cache
I install zip from sd card 'miui_nekenn6_abby_3.11.29_b43359d874_4.2-ml', I know this works as I have installed it before. The install seems to go perfectly & tells me its finished & i can reboot. I reboot and it just stays on the green android man at the start. I restart into recovery, mount sd card to pc and find that no files are in the internal storage. I have tried the process many times with the same result.
Why has it stopped unzipping the files from the .zip file to the internal storage & what can I do to solve this?
