Help help
Hello and welcome wacoliz1972 :)
I moved your thread into your device forum here :)
Can you send regular text-type texts?
Are you using the stock messaging app?
Pictures should be converted to mms which I believe is then sent over a data connection.
Is your data connection strong?
