Root Help?!
It says this on the LG boot screen, in the upper left hand corner. But now it won't even boot into my OS. It is stuck on the LG screen.
Yes, but what did you do to get it to not boot? That bit of info in the top left tells me that you rooted your phone and installed something. That's normal to appear there if you installed something that has been loki'd such as a rom or a recovery, or a kernel.
