Help HELP!!!!
So every time I log into my Facebook app it pops up a notification that says:
Samsung galaxy would like to access your fb account....
How do I get rid of that. I've tried it all!!!!
Have you gone to the FB app. settings and see if you can deny Samsung access that way, or at your Samsung account? Did you do a factory reset?
I assumed this was just so FB knew your device could use the app. Since they are so "lax" on users data. Hahaha. They donthe same thing when you want to post to FB from webpages or games they want your "permission" to link that website/app to your user account.
You can just tell it to sync then uncheck the boxes. Then skip all the other mumbo jumbo it asks you to do. If you dont like that option the other option is to not install FB and just use the mobile browser to surf FB.
I use the app for now with calendar not sync but contacts to sync. Using the app also allows you to view your pics you have posted on FB without needing to open the app.
