Help
Ace_tECH
Hey guys I would really like to know if anyone else who has a GS6Edge have suffered lag during app scrolling or app transitions ? And does your Internet always "unfortunately stop"?
Thx....I'm really worried though
That should not be happening. Try clearing your cache. Also check RAM usage, many S6 owners are suffering from memory issues caused by bugs in lollipop. Apparently an update to fix this is expected soon. If all else fails, backup your data and do a factory reset. Best of luck
Just to add something to this, You actually can't clear the ram on an s6 with a button in the system. The best way to clear the devices ram is to restart the phone and keep your background apps to a minimum, you just push the button on the left side of your home button and tap clear all
