Hentai Search Engine
The first open beta is released onto the market.
Searches a huge database for images of anime with whatever category you specify based on tags. Lets say you like cat_ears or bunnysuit well theres like over 9000 pics of that.
To Test The app :
1. Market
2. Search : Witch Dev
3. Find the Hentai search engine
Just downloaded it, and haven't tested long but one thing I would suggest if you are going to keep working on it, is to raise the max images to more like 100. Also maybe a hold-click for viewing the full size image in a new tab, or download it to a folder in the image gallery. Then a hold click on the full size image has a save or close option. I see it saving to my SD card but I can't find the images through the picture gallery for droid. Maybe I am just not looking in the right spot. I don't see the "full size" button either on my droid X just "View Tags" which always results in "LLLOLLOLOO" and as I said Save to SD seems to save it but not sure where to go to view it.
Hope you keep working on it! :D
