cdodd1019
WARNING; This May and Will mess up your phone if you do not know what you are doing!
I can not help you if you do mess up your phone, be sure you made a back up or that google sync is working. Play around at your own risk!
Take out the battery, put it back in. Simultaneously press Call(Green/Send key
) Enter(Middle Trackpad) End(Red/Hang Up) buttons on bottom portion of front face. It will turn on and display "Samsung" and fill a grey bar, then turn yellowish, poof you are now at the self test menu.
From there, go to reset and you should be able to hard reset the device.
