heya need some help
iamscott
hello i am scott :)
i recently purchased a samsung galaxy note
i am a little worried to when i download apps as when i look on the
information about them it says:
1: storage. modify/delte usb storage
2: network communication
3: phone calls: read phones status an id
there was one where it was sayin about maybe extra charge to me?
i was wondering if any one had been charged extra or if there is any security issues with some of the apps..
i hope someone may be able to help me as i have delete most me apps as not to sure if there 100% safe
many thanks for listening scott
Hey there. Have you read through this thread?
http://androidforums.com/android-ap...explained-security-tips-avoiding-malware.html
Basically, the most sound advice is to only download apps from trusted developers who have a good rating on the app with lots of downloads. Reading the phone call status is the one that always gets folks. Generally speaking, it means the app will pause or close when a phone call comes through (such as a streaming music app like Pandora).
You'll always be prompted for extra charges (called in app purchasing). You may download a free game, but in order to go further in the game, you might have to purchase those levels. You can always say no and forget about it or uninstall. Nothing will be forced on you. Always remember, for paid apps, you have a 15min period to demo it and return if not satisfied.
Thank you for your reply.. ill be looking through that.
im only worried as i had been told after buying the samsung galaxy note that some of the apps wasnt safe at all..
These permissions look 'dubious' but in fact they're just saying they need to use certain functions of your phone, internet, calling, write to SD etc etc...
I believe the wording of these are a little misleading.
What you should do is only get apps from 'decent' places like appbrain or google play. And then you should read the reviews of other people who have the app. Just use your discretion.
Occasionally an app will have advertising intentions & you might recieve push notifications in your notification bar (spam, basically). An app like Add-ons detector will let you scan for apps that do this, then you can uninstall them.
yeah they do look a bit dubious... im all getting very weary to what i dwn load its nothin that has less then 3-4 stars and read comments too soo in theory after reading the link you gave me i shud be okay thou well i hope soo :)
