Hi, and question about developer.android.com
jounihat
Hi to all,
I just registerd to ask how can I block the developer.android.com header div? It takes a lot of screen estate for nothing. I tried Adblock, but it could only block the background image, not the div itself. IMHO Google employees should know better than anyone else that elements representing frames are awful practise unless you have a very very good reason for them. (80% blank space and a couple of links is not a very very good reason.)
Also, I downloaded the Android SDK Documentation package within Eclipse, but I cannot find the documentation anywhere. Where is it hiding?
Ok, I downloaded a Firefox plugin called "Customize Your Web". With a couple of modifications I was able to remove the header and increase the height of the content views. So now everything is ok (except that I the whole header frame thing is still plain wrong wrong wrong!).
