Hi Everyone
Welcome to Android Forums. I hope you enjoy your device when you get it and that you will use these forums to get the max use from it. Thanks for joining the community. I hope these forums serve you well.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
