Hi from Aexol
Hi Artur. :)
Glad to have you aboard. For some cool tips and info on your device - check inside your device's area of support. You can select your device model from the list here where you can interact with the other users -- who will give you help to get the best out of your device.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
