mysticspiral
Android Expert
I have found that the only way to get into the hidden menu is to be using the touchwiz launcher . If u are using another launcher u. Can only get into wallpapers or gallery .
.this is where u can add launcher actions and shortcuts to ur phone . And so much more. Remember holo launcher needs to be downloaded first . As for touchwiz I will get back to you on that one I did find some pretty cool stuff .
Awesome find.I use ADW Launcher EX 1.3.3.8 and you can also do that with the custom shortcut option as well...![]()
This works with the Apex Launcher also! Very cool! Although I don't know what most of the stuff in that menu does.
and also after intall of apex launcher a home icon will appear in status bar giving option to import desktop data . Ya like i said badass . Hoora
sorry
