Hide Wi-Fi Network Symbol
  • Start date Start date
A
Android Question
Guest
I just want to hide wi-fi network symbol from my android phone.
I don't want to let know other that i m using wi-fi password in my office.
Thanks a lot....
If you are using the built-in wifi feature, your phone must be rooted to remove or change the notification icon. If you are using a 3rd-party app ands are on Jelly Bean or KitKat, you can go into Settings > Manage apps, and disable notifications.
Another option is to use an alternate launcher that allows you to hide the notification/status bar. Of course, that will make all notification icons go away. Apex and ADW both have this feature (probably others as well).
