thakiddchuck
Hi I have a new sero 7 pro that all of a sudden wont charge or cut on at all! Without the charger plugged in it doesn't do anything no matter how long u hold dwn the power button. With it plugged in holding down the power button will just make the red dead battery icon cum on then back off, if u continue holding it itll do tht 3 times then after it goes off the 3rd time nothing will happen no longer how lng u hold it until u release the power button nd hold it dwn again, which will just make it repeat the on and off process again. it does this exact same thing when u hold dwn power and either volume - or volume +, which I read is suppose to send it to restore mode. can I get any other ideas from someone experienced with tablets or computers? I am in school for programming so I know my way around computers and will be able to easily(I learn fast) perform whats needed. I lost receipt so I cant send in...PLEASE HELP...I have schoolwork on it I need...thank you for taking the time to read this
p.s the charging port is a LIL loose, u have to hold it up a lil while holding power button to get the red dead battery sign to come up
