Broke down and bought holo launcher.. Is there any way to keep all apps in the All drawer once you have them in a separate one? Example i made a drawer with 10 programs but they don't show up in my all tab any more..
Seems odd. I just set HOLO up on my Galaxy Player. I just drag apps onto a screen, then drag them together to make a folder/drawer. Those apps stay in the main app drawer and the folder. Apps in the main drawer are alphabetical. You can "hide apps" from the app drawer screen, but they are not hidden by default.
Ahhhh I see. I don't use tabs, actually deleted all but the "All" one. I prefer a screen link to "groups" (folders), with a newly assigned icon (or text).
I've used Holo awhile and never really noticed this as a problem (always go to my custom tab to find the apps I put there), but thanks to op for pointing it out.
One workaround would be to create a custom folder (call it All2) and put everything in there (you'd need to uncheck "ungrouped only" in order to see all Apps for selection).
You could even delete your All (can always be re-added later if you change your mind) and use All2 instead.
But then you won't get new programs in there unless you manually add them each time you install a new program ... not a particularly pleasing solution
