Help Home and menu display
ptheak77
Hi have just started using an xperia ray, so i apologise if i am being thick, but i took a call today, after call had ended there is now a gray stripe down the right hand side of my home menus, and when i go onto the apps menu it is now out of alignment, everything seems to have moved to the right, as if there is no page break. anyone know how to fix this please, its annoying. :confused:
I am sure you would have but if you haven't please do a reset of the phone.go to settings, privacy settings and then factory reset.
Hope this helps.
