When I press the blue apps icon on the home page of my Lucid-LG phone, it gives me a screen that says "unfortunately, home has stopped". Why is that and what to do????
Welcome matthews2!
Thanks for joining!
Although I am unfamiliar with your device, could it be that is the launcher that has stopped?
Have you tried a battery pull and try again?
Otherwise, here is a link for your device: http://androidforums.com/lg-lucid/
Someone there either may have had that issue, or can help ya!
I would suggest to take Mike's advice and try and pull the battery and restart the device. Otherwise if the problem persists you probably have a software error in your device requiring a Factory Reset, which will delete all of your data. However, if you are looking for some other device you can take that Device forum link that Mike provided above.
