Help Home keeps going back to Touchwiz
Folks,
I am not sure if anyone else has experienced this issue. I have tried two launchers so far with my S3 - GO and then Nova. Both the times, often, after extended usage of phone traversing multiple apps, when I do multiple <BACK>, I end up with my touchwiz screen. Of course, if I press the home button then I go to the current launcher. I never faced such thing when I was on FroYo on my older phone.
Any clue on how to stop Touchwiz from appearing till I enable it explicitly?
Cheers
You can also use a Home Switcher. It almost always gives you the option to "set as default". If you are going to be trying multiple launchers it is kind of a nice util to have. Allows you to ping pong between launchers easily.
