itzpacmann
So, I was wondering what home launcher is best for battery saving. Which one would use les resources while its running. Some ppl say Go Launcher is good opposed to the stock launcher, but wouldn' t you think it was use more since it's doing all the diff effects and other stuff that the stock launcher doesn't do? Which launcher do you think uses less? Thanks
