A Alice Neaves Guest Jun 7, 2016 #1 My weather widget shows the wrong location than it used to and I want to correct it! Do it is also wrong on homepage!
K karasahin Member Jun 7, 2016 #2 Alice Neaves said: My weather widget shows the wrong location than it used to and I want to correct it! Do it is also wrong on homepage! Click to expand...
mikedt 你好 VIP Member Jun 7, 2016 #3 What weather widget? Is it giving you weather for Hong Kong or something? Are you using WiFi location?
