I recently rooted my Epic 4G following this guide: joeykrim-SDX - Permanent Root for Epic (and Verizon Fascinate) - Confirmed
I then went ahead and removed some of the "bloatware" applications using this guide here: [GUIDE] How to Remove Pre-Installed Apps for FREE - xda-developers
I did successfully root my phone, and the applications I removed are no longer there, but now the shortcuts that can be placed in the Home (or any section) no longer remain after I shutdown the phone. Widgets and Folders on the other hand do get saved by the phone and remain after a reboot.
Is there something that I may have removed that shouldn't have been? and if so is it easy to recover?
Would a custom ROM fix this situation? Or is there a program that I can use to restore all the default applications (without un-rooting).
Thanks for any help,
Trev
(would doing a hard reset fix the issue? If so I'll just save my pictures and do that!)
EDIT: just realized how many questions are in this post ^_^
Trev
