home screen folders
Hey there need help on how to create folders on my home screen (running honeycomb on galaxy tab 7500) i know that on my phone (galaxy s2 running andriod 2.3) it is as simple as tapping and holding down on the home screen, and a menu with the option to add a folder appears, however there is no such function on the tab please help!!!
I don't know if it works the same wa in Honeycomb as it does in ICS, but if you drag one home screen icon on top of the other, it creates a folder with both icons in it.
Apparently they figured with a big tablet screen, you wouldn't need folders and left them out of honeycomb ;) As far as I know there is no way in the stock OS.
I've heard of an app for that, apps organizer I think, but haven't used it myself.
Found a solution, there is no way to do it with honeycomb self as such but there are several apps that do exactly what i wanted. The best one of the bunch that i downloaded was smart shortcuts intuitive ui and a lot of options to customize shorcuts and folders the way i want them. I am still waiting for the ics update for my tab, eta for the release is end of march, cant wait!!
