home screen motion?
ec34500
Member
just got the s6 and noticed the icons on the home do that motion thing like the iphone does. is there anyway to remove this? I know in the iphone you can, but I can't find anywhere in settings to remove this.
thanks!
To do this is a little complicated but some of the steps are worth it. You have to enable Developer Options on your phone. Once you've done that, you can eliminate all animations on your screen.
For Developer Options: Go to Settings and and then to About device. Scroll to the bottom of About device till you come to Build number. Tap on this seven times and you have now enabled Developer options in Settings.
In Settings search for Developer options and scroll till you get to Windows animation scale and then tap on it and set it to off.
You will notice your phone is also slightly zippier when you have done this.
that is pretty easy thank you! but what else will this turn off animation wise since it's all windows animation and not just the home screen?
