Help Home screen process crashes
Hi,
I have a sony ericson xperia x8. Ever since i updated my phone software home screen crashes with the message "the application home screen(process com.sonyericsson.home screen) has stopped unexpectedly. please try again".:confused::confused:
It could be the update didn't install correctly, I'd suggest to run the Repair Phone option on the PC Companion to see if that fixes the issue.
Hi, I'd just like to thank you Josh I literally got my Xperia Arc today and I applied an update after it requested me too when I hooked it up to my PC, I did the update and then got the home screen error. I thought the update had screwed up my shiny new phone before I'd even used it.
Thanks to your post I re-applied the update and it has cured the problem so I am now looking forward to getting it set up and starting using it.
Thanks Again, feeling relieved it wasn't a serious failure.
Cheers
G
Cheers G
Glad that you sorted out your problem, and I'm happy I could help you.
And fateinmyname, to get the Repair Phone option do this:
Start PC Companion without the phone connected to the PC, click on the Start Button under Support Zone, then click on Software Update. There will be a pop up window here saying "Your phone could not be found" and at the bottom of that windows in a blue link it says "Repair phone". Click there and follow the on-screen instructions.
