Home screen switched
I have Android 10 on my Galaxy Tab 8". Today when I turned it on, my home is switched with a secondary screen. When I push the home button, I get the second screen. All of my groups are now on the secondary screen instead of the original first screen. I am so fed up with the bugs in android, I will never own another device with android. This is obviously a bug in android, but what is the fix?
why are you blaming android? samsung likes to put their own flavor to the android os. it is called One UI. so you are most likely looking at the updated One UI.
which galaxy tab are you on? Tab 8" could be anything. this will help in determining which One UI you have.
also you might want to switch to a custom launcher. i'm not a fan of One UI. i use Nova Launcher which is free and then i use Nova Launcher Prime which is not free, but it unlocks so much more customizations. its a one time fee that i purchased over 10 years ago and i still benefit from it!!!!!!!!!
I am blaming android, whichever flavor it is, because I have had so many problems with this system. Thanks for the suggestions.
You'll find it over there somewhere -------------->>
Have a nice day.
